No service on my phone
I got this phone from my sister, I started it up and everything was working perfectly. After 1 day it said "No Service", so I reset the entire phone and it worked again, but only for 1 day? Can someone help me? I've checked the Time and Date stuff, and reset the network settings, didnt work for me. The Wifi is working perfectly. It seems like it can only read my sim card for only a couple of hours before it goes to "No Service". Any suggestions to how I can fix this? antenna problem?
Это хороший вопрос?
6 Комментариев
I have a feeling the phone might be IMEI blocked. Check the IMEI number of the phone here:
http://www.imei.info/
You can dial '*#06#' to display the device's IMEI. Otherwise you can go to settings > general > about phone to check the IMEI number there.
из Ben
Hey Ben. I can see my IMEI number atm, but in a couple of hours when it goes to "no service" again i can't. I checked the website you linked but i dont know what to look for, im not so educated in this. Could you tell me what to look for?
из Jone W
Never mind you can't check the IMEI on free on there. Do you know if the phone has been repaired before or dropped?
из Ben
Have not been dropped, have tried to repair this issue, they fixed it for a week then the problem came back. As Im writing this my phone goes back and forth between "no service" and working.
Thanks for trying to help :)
из Jone W
Try to use imeidata.net it's a lot better than IMEI.info
из Gigabit87898
Показать 1 больше комментариев
