Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Phone won't turn on after battery replacement.
Hello there
Today I replaced my iPhone's front panel (backlight issues) and battery (didn't hold charge very well).
Everything went smoothly, more or less, but when i put it back together it didn't start up. I suspected the new battery was dead, but even after charging it for an hour it didn't seem to change anything.
Then i decided to disconnect the power ribbon and try turning it on while it's connected to a charger, which didn't work either.
However, when i connected the old battery it had booted up properly.
Is my new battery malfunctioning or am i missing something else entirely?
Note - with the new battery in the phone doesn't draw any power from chargers
Это хороший вопрос?
Оценка 2
1 Комментарий:
Okay, so i got another battery (different seller) and the same thing happens. Chances of getting two defective batteries in a row are kind of low so i'm suspecting the problem is on my end, somehow.
The phone charges normally on the old battery, so the charging port isn't broken or anything
из
Добавить комментарий
1 ответ
If the old battery is booting up fine then the issue will be with the new battery, probably a faulty part.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
sebastianflorkow будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 952
