Repair guides and support for your Samsung TV.
2492вопросов Показать все
Thin red line on TV screen
Hi,
I have samsung UA37D5000 tv. There is thin vertical red line appearing in TV. When I called up the local samsung service guys to check, they said they have to replace the panel and costs almost 23K. I don't believe in their words. Will you be able to tell if it's the real panel issue or some board issue.
If I have to open the TV, it would be helpful to have a teardown guide for my TV.
Attached the picture of the red line on the screen.
Thanks
Rajesh
Это хороший вопрос?
Оценка 13
19 Комментариев
I have same issue
из
karenggivens same TV? Same issues? If so then it is the same answer. TAB error.
из
I have 40" Samsung Curved LED TV. I have the same problem. Vertical line is approx one feet from left side and stationary. Please suggest.
из
I have the same problem. I check the tabs, applying pressure where the red vertical line originated but it did not solve the red line problem. What else could it be?
из
so ii have to dismount the back from the tv ???
из
Показать 14 больше комментариев
Добавить комментарий
4 Ответов
Выбранное решение
Rajesh Ravindran this sounds like a TAB error. You need to let us know which direction the line goes (horizontal vs. vertical. Take the back off and see if you can see the flat ribbon cables that go into the LCD panel. Apply some pressure on those cables at the place where the line originates from. If that changes the line you know that it is a TAB error. Sometimes applying that pressure is enough to fix it before replacing it. Take some pictures of what your TV looks like with the back off so that we can show your were the tabs should be. Also post an image with the TV on so we can see that line. Use this guide for that.
Был ли этот ответ полезен?
Оценка 5
26 Комментариев:
Rajesh Ravindran yes Sir that is a Tab error. You'll have to remove the back of your TV and see where the flat ribbon cables enter the top of the LCD panel. Put some pressure on that cable and you should see the line disappear. LEt us know what you find. If you are unsure take pictures and post with your question so we can help you further.
из
Thanks a lot...It worked...You saved my Rs 23,000
из
sir i have HCL 15.5" monitor model-Y156W. i have same problem one vertical thin red line is come in my screen plz solve my problem
из
I have a Samsung un75ju7100f with this red vertical as mentioned above. Could this be a Tab Error also. Would like to know before I remove the back of my tv. Thanks in advance!
из
@teaba99er yes it could and most likely is a tab error.
из
Показать 21 больше комментариев
Hello. I had the same issue a few years back with my Samsung tv. After taking the back panel and trying to also find the source of the problem, i watched a YouTube video with a man that just tapped the rear top of the tv were the lines where somewhat hard and the lines disappeared. So i did the same and they went away till this day.
I hope this helps.
Оценка 3
2 Комментариев:
I just read this advice and got up and knocked on the top back of the screen where the line originated and it intermittently went away and returned so I squeezed the top and knocked it a few more times and it went away for good. Fantastic advice Angiel!!!
из
Yes this worked just saw a red thin line on tv so I tapped right above the red line and it disappeared thanks y’all!!!
из
I changed the screen.. That's the only solution.
Оценка 0
I have two thin vertical lines near the center of the screen on my 13 year old 46” Samsung LN-T4665F.
Lines appear on cold start up. Squeezing the TV at the top, right above the top of the lines will sometimes change their color (yellow, red, blue, black, magenta), or make them go away.
The lines go away after the TV gets warm.
Does this sound like the TAB problem?
Оценка 0
Добавьте свой ответ
Rajesh Ravindran будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 82
За последние 7 дней: 414
За последние 30 дней: 1,752
За всё время: 219,464
