Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
1539вопросов Показать все
sudden death , only battery led's work
Hello, I have this macbook pro that suddenly died. If i press the power button, the small led light on the bottom right turns on once. Also the battery leds work like normal. Battery does charge. What could be the problem?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
I'd try am SMC reset. Here's how:
https://support.apple.com/en-us/HT201295
PRAM & SMC
http://www.makeuseof.com/tag/reset-macs-...
Был ли этот ответ полезен?
Оценка 1
Комментарии:
thanks mayer, resetting the smc did not help... what else could i try? thanks in advance.
из
Let think on this one a while. I need some more clues. What will it do? Any sounds or the lights, any fan activity, any system upgrades, have you opened any email attachments. Do You have a way to boot externally or use Target Mode, an external enclosure? Since you are a contributor to the site, we need to get you fixed.
из
Добавьте свой ответ
ifixshop будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 338
