No sound from any media after screen replacement + 5.1.1
I've had this device for a while now awaiting funds for the replacement LCD. Previously the device worked, all functions normal, apart from occasional App and touch screen lag and wifi connectivity issues, which I think are common to this device.
Previous history:
1 previous owner, device had been dropped and bent. Battery replaced along with the mid-frame and screen assembly. Charging port, volume rocker and S-Pen replaced too.
Replacement LCD had then developed a crack and then stopped working and needed a screen assembly replacement once again.
I replaced the screen assembly and booted up to the previous software version (something around the 4.2 mark).
I have done exhaustive research on these issues and have tried practically everything. I'm hoping someone has had the same combination of problems or may know what I could possibly be doing wrong.
Issues:
• No menu/touch sounds from loud speakers or headphones, (see below)
• No media will play, if I try to play a Youtube video, the player reports 'there was a problem...' (even when wifi is OK) No sound files, MP3's, etc will play. All proprietary media players either report an error 'could not play this file type..' or crash.
Other issues:
• extreme lag when using the device, random 'sleep/wake' - volume change lag, random freezes in menu, almost unusable in current state. Random reboots into safe mode.
• S-Pen is physically attached but displays 'S-Pen Detached' in top left corner.
• Wifi connection poor, cuts out if more than 4-5 metres from router. No other device effected. However, I was able to download software update.
What I have tried:
• Installed 5.1.1 which fixed the App lag, all other problems persist.
• Cleared partition cache, nothing fixed.
• Reset to factory, no change
• Continually rebooted device, no change
• Checked physical connectors, antenna, loud speaker, etc, removed battery. no change.
Any help would be really appreciated before this thing gets binned!
Это хороший вопрос?
