The Canon Pixma iP3600 is a compact inkjet photo printer that weighs 12.3lbs and is 17.0”(W) x 11.7”(D) x 6.0” (H). This wired printer was released as part of Canon's Pixma series in 2008.
23вопросов Показать все
The rollers are not pulling the paper through for printing.
The rollers are spinning but the paper is not being pulled forward for printing.
Это хороший вопрос?
Оценка 5
3 Комментариев
I'm also having this problem with a Canon MG4100 , I'm having to push the paper through to get it going, pain in the a**e ! Any advice would be much appreciated.
из
The rollers is not pulling on top feeder, can anyone help edible canon printer
из
Solution is not to buy a printer with Canon on it. Replacing rollers is more practicle but these are disposible printers so not made for replacing parts only the garbage bag in the can.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I suspect the rubber on the rollers are worn out so they can no longer grip the paper.
You can spray this on the rubber and it will work again.
https://www.amazon.com/Max-Professional-...
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thanks I'll give it a try
из
Canon printers have a function where they can self-clean their rollers. It might need further service, but it's worth a shot. See https://support.usa.canon.com/kb/index?p...
Оценка 0
1 Комментарий:
Why cant you just replace the %#*@ things?
из
Добавьте свой ответ
childcare513 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 22
За последние 30 дней: 91
За всё время: 4,418
