Portable wireless speakers from Logitech released in 2013.
70вопросов Показать все
UE BOOM 2 Doesn't Turn on But Charging Light is On
My UE BOOM 2 has a charging light (white) when plugged in but it isn't turning on. The reset didn't work
This happened after I put in in 2 feet of water for the first time. I took it out and we used it for about 5 hours after that and it worked great. It went to low battery in that time, I recharged it and it was still working fine.
I didn't use it for a couple hours and later that night I couldn't turn it on and it was just making a weird buzzing noise all night and all day the next day.
Now there is no noise. Only the light when charging
If amine could help me I'd really appreciate it.
Это хороший вопрос?
Оценка 1
1 Комментарий:
My speaker lights up when plugged in but when I unplug it no power and I cannot get it to do anything else but I did not get it wet what do I do
из
Добавить комментарий
1 ответ
Am try to open your ue boom2 and disassemble it and check if theres a moisture inside of it and just try hot blow dry it... couse i have the same problem and it just make i work...
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
George Nelson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 2,468
