Can my Lacie mini(1Tb) be repaired?
Hi community!
Needed help with a Lacie mini (1 Tb)! So the question is if anyone knows a place were I can find replacement part to the board that has the connector to the usb that's inside. I was able to open it up however I can sauder it because of the tiny chips surrounding it, which would result to them melting. Any suggestion of what I can do to repair it! It would be much appreciated!!!
Это хороший вопрос?
Оценка
You should be able to substitute any sata to usb board if it has the correct size
из echow2001
Thanks Ethan! for answering my question!!!
из ismael camarillo
