A splash-proof, portable Bluetooth speaker from JBL, released September 2015.
29вопросов Показать все
JBL Connect drawing App malfunctions, no effects
The drawing function (last one on the right) in the Android JBL CONNECT App V 1.7.3.4 doesn't produce any drawings on the speaker, the only effect after drawing eg "Hi" on the screen is that the lights go off and a 2cm orange stripe appears in the rear part on the bottom... Very disappointing ...and I already updated it to the newest version from Aug 2016. Any idea what's wrong?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hello, I have the same problem with the drawing function, and I also have a problem with the JBL Prism color sensor lens that doesn't detect the color I'm pointing. Do you have the same issue ? And did you find a solution ?
Thank you in advance.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
The drawing function just sucks because I have the same issues. However , the color selection works great. What you need to do is place the lense directly on the object or color you want. Cut off any outside lighting to the object. I mean really push the lense against it. Then press the button. That works 99% of the time for me.
из
Добавьте свой ответ
Mat будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 530
