Why is my iPhone 5s black screen apple logo and wont charge
How much to fix iPhone 5s black screen after apple logo goes on while charging
Это хороший вопрос?
Это хороший вопрос?
From the Apple Support site:
Try putting your device in recovery mode this way:
Plug the device into the computer and hold down both the sleep/wake and home button together until the iTunes logo appears on the phone.
Sometimes when your device is in a reboot loop this is the best way to put it into recovery mode.
Normal Recovery Mode Steps:
1: Disconnect all cables from your device.
2: Hold down the Sleep/Wake button, then "slide to power off" to turn off your device.
2(alt): If the device is unresponsive you may need to power down the device by holding both the Sleep/Wake and Home button together and then release them immediately when the screen goes black.
3: Ensure that the device is fully powered down
4: Press and hold the Home button and plug the device into your computer. If your device doesn't turn on automatically, turn it on. Don't release the Home button.
5: Continue holding the Home button until you see the Connect to iTunes screen.
6: If iTunes doesn't open automatically, open it. iTunes will alert you that it has detected a device in recovery mode.
7: Click the "Restore" Button. Then click "Restore & Update"
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 65
It does boot loop, or simply just turn off? Does it only happen, if you plug in the charger?
из Freddy Krueger
