Cadillac Eldorado problem ater over-passing the VAT's key sys
hello ,
My 1994 CADILLAC ELDORADO's Dashboard stopped working after over-passing the VAT's key sys by cutting an orange wire that reads the Ohm value of the built in resistor on the key , so i directly installed a similar ohm value directly connected to the wire and the car started .
1- the cars battery was dead so we had to pulse it using another battery
2- i first installed the resistor in parallel with the wire before cutting it but the car wasnt starting .
3- smoke came from the car's Dashboard and a smell of burning plastic or electronic components (we removed the battery that was pulsing the car and placed them back)
4- before placing the battery i cut the orange wire that was coming from the steering wheels and placed the resistor to the computer interface .
5- the car started but the Dashboard was dead (speed ,rpm , fuel sign , the interactive interface )
note: when the smoke came the first time , the dashboard was well functioning . but it stopped afterwards .
my question is ; what do you think happened ? and how can i fix it ?
thanks for your time and support .
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
