Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
62вопросов Показать все
cellular disabled by vendor
I purchased a used Model a1490 from a baggage reclaim store. The cellular function is disabled. The model number reported in general/about is mf066ll/a. There is not a mini sim installed. I have installed one and it has made no difference. When I ourchased the unit the clerk said they disabled the cellular. I'm wondering if there is a way to return that functionality
Thank You
Это хороший вопрос?
Оценка 4
1 Комментарий:
Have you tried a standard ios restore? Does iTunes even recognize it? I have a feeling it may be a fake (non-apple) device.
из
Добавить комментарий
1 ответ
My guess is that the device has a bad esn. After the original owner lost it they probably didn't pay it off with their cellular provider so the device was blacklisted. The people that sold it to you didn't disable it, the wireless carrier did. Once a device has a bad esn/imei, it's pretty much not possible to make it good again. Of course, the wireless carrier can only stop you from using the cellular data function, nothing else. So you basically now have a wifi iPad
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Would this go for all carriers? If it is blacklisted by one it is blacklisted for the world?
из
If it's blacklisted by a carrier it is at least whole country. Not sure about overseas though.
из
Добавьте свой ответ
william mckinley будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 421
