Replacement 42mm Screen doesn't fit
I purchased a replacement screen from iFixit and followed the replacement steps. Now when I am putting everything back together the screen doesn't want to fit back on. It sits flush all of the way around except fro the top. When I look at the side that is not closing properly I see two little tabs that don't appear to be on my old screen. Now I am not sure if they were at some point part of the original screen since the screen was broken and came off of the watch in pieces. Here is a picture that will hopefully help show what I am talking about.
Thanks
Chris
Update (08/23/2016)
Here is another picture. It shows the side where the clips should clip into.
Update (08/23/2016)
After resetting the watch and repairing it, it appears to work properly but I still can't get the screen to sit flush.
Это хороший вопрос?
3 Комментариев
Can you see any broken clips under where these tabs go?
из Harley Greaves
its like there are no spots for the tabs to slide into
из Chris Martin
I'll take another picture when I get home in a couple of hours
из Chris Martin
