To all of us that are having the same problem-get hold of me after DEC. 17 Th, as I am going in for major surgery now, and we shall try an go thru the motherboard,together. Also not trying to be rude,but get hold of a few very small alligator clips, 4 - 6 of them, which you will keep in the freezer for "Heat Shunts" while soldering,the units on,if you do not already do so. I also at times, put my capacitors,and any sealed units,I am to solder on, put them in a zip-lock with 2-4 little sachets,or little barrels used in medical pills-vitamins ,etc, and put them in with the components,to keep the moisture down. DO NOT LEAVE THEM IN THE FREEZER FOR DAYS,AS SOME COMPONENTS DO HAVE FLUIDS OF A SORT, CONTAINED IN THEM ! Most Important. these can freeze and burst , or split the units, 15 - 20 minutes ,MAX, say no more. Talk Soon- Jon .E mail I will give you when we talk next,gang
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
bjornbertilsson you need to let us know what logic board this is. check any idenyifying numbers on it and let us know
из oldturkey03
It has a sticker saying: Foxconn L S-36
Rev A00
из bjornbertilsson
cn-0t1663-13740-449-01gu
из bjornbertilsson
