Airport is conected but it won't load anything
My iBook G3 connects to my router but when i open safari i am getting
" Safari can't connect to the server"
Safari can't open the page "http://google.com/" because it could not connect to the server "google.com"
My internet loads perfectly if i connect it via ethernet
I am wondering it the problem my airport card
Any ideas?
Это хороший вопрос?
Оценка
0
might not be a problem with airport card . might it be possible that this airport has been assigned a static ip address ? to find out; go to network preferences(click the wifi, usually last entry on the drop down menu) and make sure the ip address the airport is getting corresponds to your other network devices.
из Reboot Gozo
You also may want to check your WiFi Router (AP) to check its settings. Remember this system only supports 802.11b. Your Router settings may not have it 802.11b services enabled.
из Dan
