Repair guides for German-made Leica cameras.
9вопросов Показать все
Error code 2 on a Leica DMR monitor - source and solutions?
Good morning. Has anyone ever run into the Error 2 code on the monitor of a Leica DMR unit? The unit will power-up and display the Leica splash screen and then the Error 2 message covers the screen, and the shutter will not activate - though all other functions of the unit are available ( menu access and settings are available as are the setting for ISO, USER, Moire, etc.) Before I start disassembling I was hoping to find someone "who has been down this road before". No schematics are available online and no-one seems to want to talk about prior repairs or disassembly on any of the pertinent user group threads.
Best regards,
Peter Stevens
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi
Yes i have 2 Leica DMR digital back - the error code 2 has something to do with internal re-charge battery that has reach "end of life time". You probably have to reset the date + time when the battery is removed and so on. Need to send it to Leica to have them change the battery if possible. (internal solder on battery)
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
fritzj213 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 390
