Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
37 Questions Показать все
overdrive is not working the way it should
when I am driving between 40 and 50mph it works fine but when over 50mph when you give the car gas it keeps kicking out of overdrive until the computer goes into default mod then it works fine
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
iPhone Battery Fix Kits
Only $29.99
Buy Now
Only $29.99
Buy Now
1 Ответ
Наиболее полезный ответ
It might pay to get a code reader on it & let us know what it tells you. Sounds like the transmission control computer is giving problems. Open it up & have a look for the obvious capacitor leakage problem with this one. These computers have a history of SMD chip resistors going open circuit, which is impossible to spot, but easy to measure with a multimeter. I've personally repaired hundreds of similar systems over the years.
Был ли этот ответ полезен?
по рейтингу 2
Добавьте свой ответ
Dale Plantz будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 73
