broken screen help with front camera
I bought a used 5c from a friend with a previously replaced screen that was cracked. When I opened it up I noticed where you plug the front camera into on the board had missing prongs and was damaged will the phone still work with a new screen?
Это хороший вопрос?
3 Комментариев
Do I just not plug the front camera in will the rest still work?
из bill
Wanted to add it still charges and when I plug it into the computer iTunes responds to it Screen I have was cracked and damaged so cant see anything on it
из bill
I can't say for sure if the phone will still work with the damaged FPC connector for the front camera on the logic board, since you said pins are bent on logic board it may stop the phone from working if it is shorting against other pins.
из Ben
