Inexpensive 5 1/4" 4G LTE 2016 phone. Fixed battery, 2 SIMs, up to 64GB microSD.
Why is my phone not turning on?
Hello, I have a BLU LIFE ONE X phone and it keeps on turning on and off when i put it on the charger. I have been trying to turn it on and it wont turn on at all. I had my phone in the car and it was in there for one night so then i got it turned it on and it worked fine then it turned off on me because it was dead. So i put on the charger and then that is when it kept on turning on and off. I am trying not to reset my whole phone because i would have to back up my photos, contacts and i cant do that because my phone won't turn on. So can somebody help me out because i need my phone.
Thank You Very Much!!
Это хороший вопрос?
Счет 1
2 Комментариев:
Without doing any testing I would say that the battery has died. This can happen when the battery go dead flat, sometimes you can leave it on charge for an extended amount of time and they will come back but sometimes not. good luck
из
Do you service dead batteries? If not do you repurchase them to refurbish. I have same issue, it tries to boot cycle and fails with battery at 0% even for extended periods plugged in.
из
Добавить комментарий
1 ответ
Try a different charger. If that doesnt work, comment below and I'll give you more options.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Different chargers ranging from 0.1A to 1.0A current give the same result
из
See a technical genius about your charging port then, or try a new battery.
из
Добавьте свой ответ
Meleyah буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 1,305
