Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3531вопросов Показать все
Stuck on Apple Logo but battery low
I have already been through this thread
Stuck in continuous apple logo loop, turns off when cable removed?
Unfortunately, my situation is compounded by the fact that my phone has no power left. Thats how it started in fact. So you plug in the phone and it shows the battery icon but only for about 5 seconds. Then it immediately tries to boot despite not having enough power. So it goes back to charging mode of around 5 seconds and repeats. It seems its trying to boot without enough power.
So even if I try the above steps, it just goes back to battery icon mode for 5 seconds and never even tries to boot up.
Any thoughts?
Это хороший вопрос?
Оценка 0
3 Комментариев
If the charging port pins don't look damaged, clean the charging port if the charging cable does not plug in fully. Otherwise you probably need the battery replaced.
из
Its trying to boot before the battery gets sufficiently charged.
из
Are all of the components near the battery connector on the logic board there? If one of them are missing that probably is what is causing the problem as it's stopping it from reading the battery correctly.
из
Добавить комментарий
2 Ответов
Выбранное решение
The problem was with the battery. I got it replaced. All good now.
Был ли этот ответ полезен?
Оценка 1
it could have aproblem with the charging port. try checking the connections on it.
Оценка 0
1 Комментарий:
Nope not a problem. It s charging when you plug it in. The problem is it tries to boot without charging enough. It tries booting a few seconds after charging begins but it should be waiting much longer.
из
Добавьте свой ответ
stuart будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 182
