Here you will find several different repair guides for the Dell Chromebook 11 (CB1C13) - 2GB & 4GB models
11вопросов Показать все
bypass enterprise enrollment on the Dell Chromebook 11 CB1C13
Ive tried to get into developer mode but I have not succeeded because it says that it has been disabled by the enterprise enrollment. Please tell me how to bypass the enterprise enrollment.
Это хороший вопрос?
Оценка 3
1 Комментарий:
l have the same problem, but l have two of the same make and model l was able to get one working and powerwash that one but have trouble with other, cant get into admid dev mode, if anyone can help or comments, advice is much apreciated, thanks
из
Добавить комментарий
4 Ответов
You cannot bypass enterprise enrollment without access to the admin console under which device was enrolled under. https://support.google.com/chrome/a/answ...
Thus, you cannot enter developer mode without your administrators permission.
Был ли этот ответ полезен?
Оценка 0
Yes it won't let me Every time I try it keeps sending me to the screen Where it says Admin is blocked
Оценка 0
what if l tried to wipe the memory and try a fresh install with different OS on a usb thumb drive , could l get into or have access to dev mode through a way like that?
Оценка 0
After a powerwash, run through the prompts that are presented in regular usage, set up wifi, and allow the machine connect to wifi and contact google. If the device has been legitimately sold off, the enrollment should drop, and regular login and guest mode should show up in the bottom left corner. If this works, you can then set it to developer mode.
If not, you can wait, try again in a few months, but it is likely that the machine was marked stolen at some point.
Оценка 0
Добавьте свой ответ
Joseph JS8517 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 3,734
