Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2193вопросов Показать все
Battery discharging from 100% to 0% within a few hours
As the title really, I've got a problem with an iPhone 4S where the battery will fully drain from a full charge within a couple of hours. I have tried a full factory reset eliminating the software and replaced the battery and still no fix.
I'm thinking this may be a hardware issue, could it be one of the ICs need replacing?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
This is just an issue with older batteries in an iPhone 4S. It is relatively easy to replace the battery. You can buy a replacement kit from iFixIt here iPhone 4S Battery
If you get lost during the process you can follow this video. (This is not my video but I looked at it and it is a good guide.) : https://www.youtube.com/watch?v=UJud8Hlr...
As you can see the replacement kit from iFixit is relatively cheap. You don't have much to lose even if it doesn't 100% solve your problem but from my experience, I would say that you just need a new battery.
If you need anything else you can contact me directly via e-mail: tyler.hoban@gmail.com
Best Regards,
Tyler Hoban
iPhone 4S Battery Изображение
Продукт
iPhone 4S Battery
$16.99
Был ли этот ответ полезен?
Оценка 2
4 Комментариев:
I have already replaced the battery.
из
I also don't think the ifixit battery is anywhere as good as an original iphone battery. For the first few months, the ifixit battery lasted. But now, after just a few hours and not doing anything, it has dropped 20% and will be completely out by evening even without using it.
из
I think IFIXIT does not sell their batteries on Amazon because they know they don't last.
из
down another 10% in under an hour on wireless and doing nothing.
из
Добавьте свой ответ
Dan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 91
