Why isn't my update restarting the phone?
When I download the newest Update for my phone it starts the Update but then when it comes to the restart point oft the Update it does nothing anymore, the work is in progress for hours and nothing happens. I tried restarting it my self but still the same Problem what can I do?
Это хороший вопрос?
Оценка 0
1 Комментарий:
I had the same problem and solved very easy with this post
Its in spanish, but you can use a translator if you need
http://www.htcmania.com/showthread.php?t...
из
Добавить комментарий
2 Ответов
Hi did you try the OTA update or the update via SD card?
No matter what, try the other way.
Before updating, check the version, maybe the update doesn't start because the update is already installed....
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I tried both ways, same result, When it says restart it is just loading endless.
из
You may need to wipe the cache:
http://bbs.vernee.cc/forum.php?mod=viewt...
Оценка 0
Добавьте свой ответ
Raphael Hoerster будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 1,156
