Windshield Washer clogged on one side?
I need to get under the plastic cover to take off my windshield sprayer to unclog it. How do I get to it?
Это хороший вопрос?
Это хороший вопрос?
Take off the weather stripping on the front of the cowl.
Go to driver side reach in the middle an push in on the clip holding the cowl in place. There are 1 or 2 more on each side that you will have to push on to get off both sides. They overlap and I think you start on the drivers side.
Unplug the hoses connected to the nozzles.
Pop out the nozzles (small clips on the sides-push up)
Был ли этот ответ полезен?
You might try using the garden hose with high pressure, to blow the dirt back inside. Then it might spray normally. You could see if the dirt can make it through the spray nozzle after that.
Or try removing the spray button from a spray can of Windex, and push the top right into the spray nozzle. The high pressure from the can should blow the dirt and any fluid back through the line cleaning it out.
If you can remove the sprayer line somewhere under the hood, you can probably just blow it out.
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 21
За всё время: 7,192
