Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106вопросов Показать все
iTunes error -1. Maybe Hardware defect?
Hi,
As anyone had seen the error -1 (unknow error)? Any suggestion for solution?
I had read, that is an hardware problem on Nand Flash, maybe right?
The iPad 3 (A1430) wont turn on after an update.
When i disassemble it, i had checked that the Main Board Flex Interconnector is broken.
I had resolder the terminals and buyed an new flex, but i have my doubts that this is the problem. I'm Wainting the Flex Arrive.
Sorry if some English errors :D
Best Regards
Paulo Silva
Это хороший вопрос?
Оценка 1
2 Комментариев:
-1 is usually the baseband
из
Hi,
I will try to Reflow it and check if it works...
Many Thanks
из
Добавить комментарий
1 ответ
was this resolved?? as im having the same issue
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Paulo Silva будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 355
