I have www-bberror-com-bb10-0015 on my screen (model STL100)
i cant locate phone on pc and cant do anything with phone because of error message please help im such a novice.
Это хороший вопрос?
Это хороший вопрос?
Был ли этот ответ полезен?
It keeps going around in loops. It does not resolve my issue. When I visit Link, I get a "Software Update encountered and error" - check your network connection . But guess what, I have full internet access. I do not have any limitation.
Both links work for me in safari.
The error you mentioned above can often occur due to various reasons but one solution is to remove the current OS and by auto loading the OS again on the device.
Download the autoloader for your device from here
http://developer.blackberry.com/
And follow the steps below:-
1-turn off your device
2-connect your device to pc
The downloaded autoloader must be present on your pc and installed or unzipped
3-now run the autoloader and turn on your device.
Once autoloader recognizes your device it will start loading OS on it again after its finished green LED will light up.
After its finished your phone will restart give it sometime and all done.
I hope this helps! Good luck!
I HV a problem with my phone blackberry z3 it say www.bberror.com/bb10-0015
Pareho po tayo
Am having a problem of error message when I start it and have downloaded auto loader but it says error message when the prompt has stated what should I do?
I connected my device to the PC and downloaded my software but still not working..please
This error comes when the mobile battery is taken out from the mobile without making mobile switch off
So its a normal error and to solve this error have to flash the mobile but it will loose all mobile data from the mobile and will be the like new one after flash
Here is software pb tool to solve this issue
blackberry dev alpha c how to download softwear
How do I fix my blackberry says bberror0015 and my phone is flash green when plugged in but when unplug it has redlight
За последние 24часов: 5
За последние 7 дней: 38
За последние 30 дней: 162
За всё время: 26,696
5 Комментариев
из dave4allng
fredreck
kalumba
из alex kalumda
Download this program, install it and hook your Blackberry to the computer and allow it to upload the OS back to the phone itself. https://us.blackberry.com/software/deskt...
из William M Midgett
Help me. My phone have a bberror bb10-0015.. I can't fixed. Because I don't have PC😭😭😭😭
из jame forever
How could I downloaded to open
Or
So that My phone can operate
из Kagiso Zeddy
