An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140вопросов Показать все
Brew Screen / Boiler Valve Issues-- what to do when its' stuck?
Recently the brew screen (screen attached to the bottom of the boiler unit screwed into the mushroom boiler valve) ended up in my portafilter. I thought, "no biggie-- just screw it back in." Well, that isn't working-- screw has somehow become too short (though it doesn't appear to be stripped or broken). Ideas? Here are mine, would love some feedback.
1. Maybe it IS slightly stripped and not catching.
2. Maybe there is an issue with my mushroom boiler valve-- went up into the machine?
2a. I cannot unscrew my mushroom boiler valve for the life of me-- tried many different times with various tools.
Suggestions before I start aimlessly buying pieces and trying to replace things? Much appreciated! ~ Stephen
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Stephen, probe the screw hole to see if it will accept a little longer screw, which will tap new thread. If you can not go with a longer screw, maybe try a bit larger diameter screw. Good luck.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Stephen Cormier будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 381
