Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
Can't resolve the deadly 3 beeps on startup
Hello everyone,
I have a Mac Mini Unibody (mid 2011) which doesn't startup anymore. It was not in use for some time and when we got it out again it gave the 3 beep signal which would indicate my RAM does not pass a data integrity check. But my RAM does work in my other Mac which uses the same type of RAM.
I have searched for the ultimate solution on different message boards and executed several suggestions made there. I have done the following:
  • I have tried to reset the PRAM, but no succes.
  • I have hold down D during startup, but no succes.
  • I have checked the Logic board, but I can't find anything loose or broken.
  • I replaced the thermal past on the heatsink.
  • I cleaned my Mac with compressed air, but no change.
My question: Is there anything else I can try before putting the logic board in the oven? As this will be my last and final step.
Hope you have some suggestions!
Ditta
Это хороший вопрос?
Счет 0
2 Комментариев
After some research I found that three beeps mean "No RAM banks passed memory testing", have you insured that all RAM cards are properly seated, and are in working order?
из
Yes, I have switched them around. I have used new ram cards (which are now in my iMac working just fine). I have reseated them, and tried both banks separate.
So as i mentioned, I don't think it is the RAM cards or the way they are seated.
из
Добавить комментарий
1 ответ
Выбранное решение
What speed are the RAM modules?
Your Mac mini might not support modules you have. I would try 1333 MHz modules then see if you have any luck with them.
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
Mid '11 Mac mini specs: Mac mini 2.7 GHz i7 (Mid-2011)
Requires as a minimum: 1333 MHz PC3-10600 DDR3 SO-DIMMs.
из
Добавьте свой ответ
Jedidja буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 1,086
