Device will not boot up?
I was attempting to downgrade my kindle fire 5th gen to 5.1.2. It was going all fine, I had gotten it installed and everything, but when I attempted to reboot it it wouldn't turn on. It is now stuck turned off. How do I fix this, or is it a lost cause?
Это хороший вопрос?
Оценка
2
Hi, Try holding down the power button for 40 seconds. If this is still no good, try holding the volume button and the power button together for 30 seconds.
If you have tried either or both options already, apologies.
Last ditch attempt: if nothing works, open your Kindle, disconnect the battery, press and hold the power button for 10 seconds, release the button, reconnect the battery and try to start it.
из jayeff
Thank you for the suggestions unfortunately I have tried all of those, none of them worked for me.
из Theifobia
Amzone Fire Tablet 5Th Gen After Downgrade Dead Or Connecting MTK Driver Showing Device
из Sikandar Ali
I have tried all ways of factory resetting but it still won’t work.
из Peyton Dotson
