Hard disk doesn't show up and doesn't spin
Hi everyone,
I had my 1Tb harddisk working perfectly except when i unplugged accidently. But it used to be fine and was working.
Last time i was using 2.0 Targus USB hub with the power of 5.0V 2.6Amp and connected my harddisk to the hub. That was the moment I couldn't get my disk in mac. I thought it was taking the time to pop up but now I knew that it doesn't spin at all.
Need suggestion plz.
Update (09/18/2016)
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Try different cables. Did you try it directly on a computer, better a different one? May be hub is defective. In the worst case, disassemble and carefully transfer the HDD to a different enclosure and try powering it on.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Sujan Bhusal будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 79
