Why is my bluetooth speaker randomly turning off? (JBL Xtreme)
Recently I've been experiencing some difficulties with my JBL Xtreme. The device will randomly turn off after about half an hour or so when not charging, even when fully charged. When it turns off I am able to start it again, but the problem only gets worse and it'll turn off again after only a couple of minutes. Eventually it becomes impossible to start at all until it's plugged back into the charger again. It boots up fully charged as well after that.
The device is about a year old and the problem occurs both while connected via bluetooth and via AUX. It's well taken care of too.
What could possibly be causing this problem? Does the device believe that its battery has been drained or something? I'm really at a loss, and appreciative of all help I can get.
Это хороший вопрос?
109 Комментариев
I have EXACTLY the same problem. 2 is a coincidence; 3 is a trend. Anyone know anything more about this..?
из rboehmer
Same problem. This is an issue. Does anyone have any ideas, like someone from JBL maybe to explain? this is making me feel that i have spent money on something that is not what it has been advertised to be.
из sometecny
Same problem. The Extreme doesn't start without connecting to the power even for one instant. Usually the shut down happens around 15 minutes after playing music from full charge. After conecting to the charger the battery seems full. Anyone has a solution?
из Ardian
I have the same issue. My Xtreme is just over 12 months old and has started shutting itself off every 10 mins even though battery is showing full charge. To get it going again, I have to plug it back in to the power. Take it off the power and the pattern repeats! Come on JBL help us out please!
из yobedemc
Same problem here. Keeps disconnecting from my Windows 10 laptop and iPhone 7. Tried everything, no luck. Maybe a firmware update would be helpful from JBL. Such an expensive speaker shouldn't have such issues.
из behenriques
Показать 104 больше комментариев
