Headphone's earphone dangling from the wire
My headphone's earphone is dangling loose from its wire, how do I fix this?
Это хороший вопрос?
Это хороший вопрос?
Recently i've also had this problem, but fixing it is quite easy.
First you wanna remove the hear cushions.
Then comes the difficult part. Finding a screwdriver that fits.
After doing that you wanna unscrew the 5 screws that holds the red thingy in place. Remove it, then unscrew 5 screws holding a black thingy in place.
Now you wanna lift the thing up. Be careful if youre on the left side (the side with the microphone) because there are some wires youll have to be careful about. If youre on the right side youre good to go (No wires in your way)
Now you should see the sound/earphone/speaker thingy. If its hanging freely, you just glue it back to its original position and enjoy the improved sound quality. (Though i would be careful about what glue youre using).
Был ли этот ответ полезен?
What glue would you recommend? Mine is the same way lol
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 34
За всё время: 4,356
Zach luc not quite sure what you are refering to. Is it broken of the fork or is the driver out of the case? Post some images with your question. Use this guide Adding images to an existing question for that. It will allow us to see what you see.
из oldturkey03
