Does not spin in spin cycle or does not spin fast enough
Hello, I have an Inglis Whirlpool large capacity top load washing machine. I bought it new in 2006 which makes it a 10 yr old machine. I'm having 2 problems with it now. First: the spin cycle will either spin too slow to get the water out or it doesn't spin at all. I reset it by unplugging it for a few minutes & plugging it back in & opening/closing the lid a few times then running it through a small cycle, which it then spins. (I read resetting it like that can help, which it did for a while) I wash a new load & sometimes it works, sometimes it doesn't. It agitates fine in wash cycle. I've been washing only a couple items at a time hoping it'll spin, but it doesn't. So I do the lid reset & try again. Most times now, it doesn't work.
Second: almost every time at the beginning of the spin cycle it'll start adding water! Then it'll go into the spin cycle after. Sometimes it spins, slowly, but most times it doesn't spin at all. Please help. I don't have the money to buy a new one so I'm really hoping I can fix it myself
Thank you!
Это хороший вопрос?
6 Комментариев
@sandylittle314 what is your exact model number?
из oldturkey03
I am having the same problem with my washer machine, It fills, agitates and drains, but does not spin. I unplug it for a few minutes, plug it back in, put in on drain and spin cycle, then it spins. Not sure what the problem it since unplugging it then plugging it back it can get the spin cycle to work, thinking something with the timer?
из zantor169
zantor please ask a new question on your specific problem
из mayer
Due to a heavy wet load.
My washer spins but slow. Checked belt, looks fine. Belt turns at an ok speed then slows down and I smell something. Any help?
из Bonsheen
motor on its way out time to replace
из David Taylor
Показать 1 больше комментариев
