Hard starting from the time I purchased it
My mower has been hard to start since the day I received it 3 years ago. It is a Craftsman YT4000 tractor with a Briggs 24 hp engine. The model number is
917.28856, motor model is 445677, type is 2188-G5, code is 121214YG
I have replaced the fuel filter, air filter, spark plugs, .....no help.
I think it may be a fuel problem however the Sears manual has no info about the fuel system and how to adjust the carburetor. Need help. Thanks...
Это хороший вопрос?
1 Комментарий
i have this problem too... replaced air filter, fuel filter, fuel pump, spark plugs... the spark plugs are bad and you get shocked if you touch the wires which shows wiring is bad; that is one reason it idle's in and out.. its an awful mower
из robert0026734
