Is it my Catalytic convertor
I ran out of gas (one time) and my car would not run after that. The fuel filter has been replaced, fuel pump replaced, spark plugs replaced, and gas tank removed and cleaned. It is still not running right and the check engine light is blinking. I filled the tank and put fuel injector cleaner in it. Is it the catalytic convertor.? If so can it be cleaned or must it be replaced? Could it be something else?
Это хороший вопрос?
1 Комментарий
Does it smell like rotten eggs? Does it run hot all the time. If so, you should have a good mechanic check it out soon. If you wait to long it may damage the engine.
из Deleted
