after 30% battery , screen with black lines and no touch
with old and new battery after 30% battery have no touch and black lines on screen or black screen , what can i do to fix it ? i have replace screen with new and the same
sorry for my poor english
Это хороший вопрос?
So the battery charges when its connected to a charger, the phone works fine until it hits 30% battery, and then dies? How many times has it done this?
из Josh W
Sound like an under voltage problem. Replace the battery the problem should be solved. Worked in 90%. You can also check your phone with iBackupBot. Read the Error logs. If you got low battery errors replace the battery.
из Marius Werdecker
every time when the battery is 30%
the battery is "new" from ebay
из kwnsak1
I would try a new battery from a reputable source like iFixit.
из Josh W
