Samsung Galaxy S5 Active SM- G870A released June 2014. Repair for this device is extensive and requires the phone tool kit and heat gun.
75вопросов Показать все
Eyeball icon on notification bar on my new samasung galaxay s5 active
how do you disable Eyeball from notification screen even after going thru steps to do so by turning off smart stay option
Это хороший вопрос?
Оценка 5
4 Комментариев
I had that problem & it was screwing up my phone, I couldn't fix it, so I took a hammer to it ! It didn't fix the problem but it made me feel much better !
из
One in awhile barley noticed it
из
A tiny dab of typing correction fluid should do the trick where the eye keeps popping up.
Annoying on a certain homewares website that l visit too someone's face appears in "chat" & won't go away when you click on the "X".
(I put a bit of masking tape over the camera on the front of the phone ) Good luck -very paranoia inducing !
из
Yes the icon bugs me out a bit
из
Добавить комментарий
6 Ответов
Выбранное решение
The eye icon comes from the function Smart-Stay which is implemented at the Samsung Galaxy S5. Smart Stay is a function which can illuminate the display as long as you look at it.
Go to Menu -> Settings -> Display In this sub-menu of your Samsung Galaxy S5 you will find an option called "Stay Smart". Remove the check mark and then the function will be disabled on your Samsung Galaxy S5. The eye icon will not appear anymore at your status bar.
Source : http://www.solvemix.com/index.php/androi...
Был ли этот ответ полезен?
Оценка 5
7 Комментариев:
i tried that option and display still appears active yet smart stay has been disabled and no check mark on. It may be a whole different problem with phone software.
из
Me to i just want to trash it
из
Yeah........me too
из
Me t.............
из
Ohh i get it now i was creeped out and thought someone was watching me but its just that setting i have
из
Показать 2 больше комментариев
Наиболее полезный ответ
The eyeball icon simply means someone somewhere is watching your every move at that moment.
Оценка 7
3 Комментариев:
Correct answer.
из
Actually. It's a Eye tracking thing that was built in with smart stay. NOT any thing that's tracking you
из
Please say you are correct
из
On my phone it's actually under settings>display>eye comfort. If its turned on the icon appears. The setting is to filter blue light which can become uncomfortable to eyes if looked into for a period of time. When turned off the icon disappears and the blue light is no longer filtered out.
Оценка 1
3 Комментариев:
Can't find >eye comfort anywhere?
из
On my phone smart stay is not checked off it is disabled and it still comes on and every time it comes on my phone freezes up and I can't do anything when it goes away my phone unfreezes
из
I have the same problem and I went into my gallery and found all these recordings on my phone of me talking to others . Go to your files and look for sunp4541. I had 396 voice recording that had been linked to my email. If you see that eyeball up there and your phone freezes up when you see it change your email and get a new phone.
из
The new software update changes this…
Smart Stay is off and I am using the LATEST UPDATE…
I hate that eye..
Оценка 0
Uncheck smart rotation in screen rotation settings.
Оценка 0
It's due to the “ Blue light filter” being on.
Оценка 0
Добавьте свой ответ
Steve будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 48
За всё время: 63,393
