Intermittently shuts down & won't charge battery.
I have a brand new battery and it won't charge while plugged into the power supply. Green light barely visible. System runs off charged battery and off power supply. After running for a while it shuts down yet it doesn't get hot. Does it sound like a bad logic board, and is that something that can be fixed? Thanks in advance for any help.
Это хороший вопрос?
1 Комментарий
Hi Mayer, thanks for taking your time to help me out. My assumption is that the power supply is original to the system but I'm not completely certain of that nor am I certain it's functioning properly. I did purchase on 2 separate occasions mag-safe boards. Both were used but the seller said they were in good working order. Prior to installing I cleaned the contacts and did make sure they all extended properly. I'm going to take the AC adapter to Apple today and see if they can tell me it is functioning correctly. I'd love to think that is the only problem here. Thanks again for your help, I'll keep you posted.
из scott8021
