Can't install OS, don't have another Mac.
Hello,
I recently fixed a iMac and I really want to use it. But, I don't have a copy of Mac OS X. How can I install the OS? The only computer I have is a PC running Windows 10. Also this iMac doesn't support internet recovery. Also again the hdd is wiped blank.
---update---
I have a copy of the lion installer. Can I create a cd with that?
Это хороший вопрос?
2 Комментариев
You're stuck in a catch22 situation here ;-{
You need to have a system running under OS-X to prep the HD and install the OS. Which is why you need a friend with a Mac. Once you can access a Mac you can then create a bootable USB thumb drive to take home to then install the OS from as it will be your boot drive to then install the OS (the OS installer) onto your internal drive.
Think of it this way: How does the Olympic caldron get lit? It needs the runner with the torch to light it. As it can't light its self.
из Dan
Good point. Thank you! Guess I have to find someone with a Mac now! :P
из Gigabit87898
