Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591вопросов Показать все
Battery did not charge, battery ondicator off, but it power up!
I have problem with my mbp 2011
Simptoms:
battery don`t charge
battery indicators off
magsafe only green
in osx it says: no battery available
if i unpluged the magsafe it goes to sleep mode.
Any ideas ?
Update (10/11/2016)
By the way, i used apple test hardware and the result are OK! I don`t find any issues. :(
Update (10/11/2016)
I have tried with a new battery but is the same issue, i have this problem after i change the thermal pasta of cpu. My question is: Mbp can run normal without battery indicator ? Or it won`t charge without this indicator cable connected ?
Thanks for answares guys !
Это хороший вопрос?
Оценка 1
1 Комментарий
Do you mean the indicator light is not working or the indicator in the top right corner?
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Battery issues more often than not are caused by a bad battery. Replace the battery with one that you know is good, and that will tell you the answer -- if it works, the battery was bad, and if it doesn't, you know it's the computer, and we can proceed further at that point.
Был ли этот ответ полезен?
Оценка 1
your battery might of reached the end of its lifespan. rechargeable batteries have a limited amount of charge/discharge cycles
Оценка 0
Оценка 0
Добавьте свой ответ
sandrinilea будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 108
