HDMI to Monitor working, HDMI to TV not working
So I can't connect my laptop to the TV (with HDMI). I thought something was wrong with my cable or laptop. But when I connect the laptop to a monitor it works immediately.
Then I thought my TV HDMI port wasnt working, but I plugged in a chromecast, and that does work..
What can I do? What can I test?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Hi,
Check the video resolution setting of the the video in the laptop and then check your TV manual to see what resolution the TV can handle. Some Samsung TVs for instance can accept 1080i (1920 x 1080 interlaced) but not 1080p (1920 x 1080 progressive) or not even 1080 but only 720p (1280 x 720) when using HDMI.
Update (12/08/2016)
Hi,
Sorry about the delay I have been away.
Here are some things to try.
First check that your laptop graphics adapter resolution is set to one of the following as these are the resolutions that your TV will accept when using HDMI.
Computer formats - HDMI
(Resolution - refresh rate)
640 x 480 - 60 Hz
800 x 600 - 60 Hz
1024 x 768 - 60 Hz
1280 x 1024 - 60 Hz
1360 x 768 - 60 Hz
1600 x 1200 - 60 Hz
1920 x 1080 - 60 Hz
If one of the above is selected and there is still no picture then try the following:
Press the Home button on the remote the select Setup > TV Settings > Picture > OK then find and select PC Mode then OK
You may have to press the Adjust button on the remote and select Picture Format > OK then Unscaled for the best picture.
If still no good this advice is from the User guide:
If the TV does not recognize the HDMI device and no picture is displayed, switch the source from one device to another and back again.
By this I assume it means that if you can, connect your laptop to one HDMI input and connect another HDMI device e.g. your Chromecast to the other HDMI input, (I think you have 2 HDMI inputs - is this correct?) then point the TV source input to the laptop, if no signal select the Chromecast input, get a picture and then switch back to the laptop and see if the laptop picture is now there.
Был ли этот ответ полезен?
Оценка 2
7 Комментариев:
I will try it this evening. Thank you!
из
This did (unfortunately) not work :( Still no fix.. I read a lot about windows 10 and HDMI problems. Can this be the case?
из
Hi, If it works to a monitor using HDMI without any special adjustments then I'm thinking that there is a compatibility problem between the TV and the laptop.
What actually happens? Do you get a 'no signal' message on the TV or nothing or something else?
What is the make and model number of your TV?
из
The TV says: 'no signa'. The tv is a philips. Its about 5-6years old. Is the modelnumber important? Than I'll check it this evening.. Thanks for the help!
из
Hi, Yes. Sorry to be a nuisance but the model number is important as the manufacturer (in their wisdom?) alters features and specifications between models.
из
Показать 2 больше комментариев
Добавьте свой ответ
Nickvr будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 17
За последние 30 дней: 74
За всё время: 15,043
