Galaxy 7 LCD, after LCD install purple spots appear! Help
A client comes with a shatterd samsung galaxy s7 screen.
She told that after the drop everything worked fine and then after some weeks the sreen started showing purple spots.
She came to me and I orderd an original samsung screen at mtimpex.com. After installing it worked perfect. Then, two weeks later, my client comes back complaining that there are purple spots and stripes on the screen and that the digitizer doesn't work good.
So I ordered a new screen at gsmpartscenter.com. First it worked perfect and after 10 minutes or so the screen showed again purple 'inkblots' on te screen. (The longer you look at the worse it gets. )
I called gsmpartscenter.com and they said that it could be the mainboard.
This sounds strange to me, because at first both screens worked fine and then after some time the purple spots and lines filling up the screen. I can't test the screen on another galaxy s7, because I don't have any laying around..
Does any of you know what's going on? Thanks!
The thing that also makes me angry is that Samsung (or is it a mean strategy of the supplier) now to put a label on the Samsung package of the screen claiming that there is no warranty when it's not installed by a Samsung Service Center!
Isn't that crazy?
So, Samsung sells there stuff to smartphones shops suppliers and then they put a label on it that there no warranty after installation, unless it is installed in a Samsung Service Center. How crazy is that! If that is the case I will loose a €210 I will keep this updated...
Это хороший вопрос?
