Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
Why is my battery slowly draining?
The battery and alternator have been checked out and are good. I can drive the truck all day and it stays charged, but I must disconnect the battery cable when I park it overnight or it will be dead in the morning. I have checked wiring on all the harnesses and they look good. Where do I look next? Is this a common problem with Fords?
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Выбранное решение
Penny, If battery is indeed good, you are experiencing what is known as a parasitic drain of battery. Parasitic drain means something is using power when it should not be, could be a aftermarket alarm/stereo, stuck relay, shorted wire/switch, faulty alternator, etc. I will post a link to show how you can check your vehicle for parasitic draw by pulling fuses and checking amp draw/power with a DVOM. Good luck.
https://www.youtube.com/watch?v=zdIKNnwE...
Был ли этот ответ полезен?
Счет 7
2 Комментариев:
Some short circuited then some current all time flowing that's battery drain
из
@lpfaff1 Excellent choice for a teaching video , really like using ETCG stuff for simple explanations
из
If alternator is and batter are good checks the starter and starter solenoid they can draw power (parasitic draw )
Счет 0
Добавьте свой ответ
Penny Peterson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 29
За последние 30 дней: 115
За всё время: 20,509
