The Dell OptiPlex 745 small form factor is a compact desktop computer that has been a work office favorite, and still sits at desks to this day.
15вопросов Показать все
Which Motherboard Perfectly Supports in DELL Optiplex 745?
I have a DELL Optiplex 745 Small Form Factor PC,
and processor is Intel Core 2 Duo e6420.
My motherboard has failed, so i need to replace motherboard. I'm in trouble to solve this problem. which motherboard(s) should i choose ?
Это хороший вопрос?
Оценка 0
1 Комментарий
Well, Thank You Very Much Simon Almeida For Your Support. Yes, you said right, my machine is old. I would like to think about changing it :)
из
Добавить комментарий
1 ответ
Выбранное решение
Your motherboard size is called "MICRO-ATX" and you CPU socket model is "LGA775". So any "Micro-ATX LGA775" motherboard will work (Assuming your CPU and other components are still good).
Here are some motherboards I found online:
  1. http://www.ebay.com/itm/NEW-Foxconn-G41M...
  2. http://www.ebay.com/itm/Intel-DG35EC-Des...
  3. http://www.ebay.com/itm/ASUS-P5G41T-M-LX...
  4. http://www.ebay.com/itm/NEW-Gigabyte-GA-...
My personal opinion, I would recommend buying a new computer. Your machine is 8 years old now. A lot has changed since. I don't think you will regret this decision :)
Best of luck!
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Sarthak будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 17
За всё время: 1,571
