Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2155вопросов Показать все
repair craked camera glass
is it possible to repair cracked camera glass on the back side iphone 7 ?
if so, how much is it??
Это хороший вопрос?
Оценка 1
1 Comment
How in god's name did you already manage to do that
из
Добавить комментарий
5 Ответов
Наиболее полезный ответ
I don't know how much they charge for it in your country, but with a little bit practice you should be able to do it by yourself:
iPhone 7 Camera Cover Glass Replacement
Был ли этот ответ полезен?
Оценка 4
I haven't seen anything for it, honestly. I'm sure if you could come across a part that it would be somehow possible (not sure the details or difficulty of course, but nevertheless)
Оценка 1
1 Comment:
I found one on eBay in about 10 seconds.
из
Here's a link:
http://www.ebay.com/itm/Rear-Back-Camera...
Оценка 1
2 Comments:
Never actually checked, thanks for the link man! :D
из
Your welcome :)
из
It would be easier in my opinion to just replace the whole back housing
Оценка 1
3 Comments:
Actually it would be a lot harder, a housing replacement would be an hour, a camera glass would be a minute.
из
i thought should be taking off the rear housing first then you can remove the rear camera glass from outside to inside
из
Has someone made it? Maybe he can give us some advices? How to disassembly the lens ?!
из
Here is a Video-Tutorial:
https://www.youtube.com/watch?v=Xm6u2FQ5...
Оценка 1
Добавьте свой ответ
nathan myoung будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 251
