Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
493вопросов Показать все
Screen & lid cover separated
Hi all. Ive just had the same problem with my 2009 MacBook Pro 15"
I've had it from new and it's awesome but this problem is unacceptable. The reason we all buy Apple and spend £2K on laptops is because they last!
The problem seems to be where the heat is vented from processor fan. It gradually deteriorates the adhesive over time.
Apple... You know about this problem - don't be awkward!
Has anybody had a permanent fix? if so what adhesive did you use.
Thanks in advance.
Это хороший вопрос?
Оценка 0
Комментарии:
See if the frame broke about 1" up from the bottom of the display on the left side (it will flex) at that point. If so let me know.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hey,
Try this website for strong high temp resistant clear adhesives and glues.
This could be useful:
http://www.masterbond.com/tds/uv25
here is their main website, Lots to pick from
http://www.masterbond.com/properties/hig...
Был ли этот ответ полезен?
Оценка 1
There is a few different issues at play here. If you had the screen cover glass replaced I've seen a few bounce back as the adhesive really needs to be cleaned off fully and replaced instead of re-heating as some have done.
The lid frame is two parts sometimes the outer shell gets a bang which snaps the screws/glue between them.
We still have quite a few of these in use for our field staff. They are workhorses! But, like laptops of their time frame they have their limits. I often find people outstretch what these systems were designed to do. Apple never intended them to be desktop replacements (just like all of the other manufactures). Laptop systems in general are for road warriors, not gamers. Yes, you can still do many games but most of the newest are just too hard graphically for these older systems.
OK, what to do here?
You'll need to pop off the cover glass and you may need to pop out the LCD so you can re-anchor the mid frame back to the outside lid. As for the cover glass you'll need to carefully clean off the old glue and then use some hot glue to re-apply it (or you can use some double stick adhesive strips).
Here is an IFIXIT guide: MacBook Pro 13" Unibody Mid 2009 Front Display Glass Replacement to walk you though the process to pull the cover glass off. Do be careful with the heat gun as you can melt the rubber gasket quite easily. Hopefully all you then need to do here is clean it up and re-attach it. If you need to dig deeper let us know.
Оценка 1
Добавьте свой ответ
Mike King будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 963
