Are you worrying about your Android phone stuck in fastboot mode? At this time, I will provide you with 5 useful ways to help you get rid of the fastboot mode.
Way 1: Long pressing the “Power” button to restart your phone.
Way 2: If you are using a phone with a removable battery, the direct way is to remove the battery and reinsert it. But if not, the way is to put your battery run out. And charge for some time to start your phone.
Way 3: Use ADB and Fastboot Tool
Use ADB and Fastboot Tool to exit fastboot mode, please follow the steps below.
Step 1: Download and install “ADB and Fastboot Tool” on your PC.
Step 2: Find the installation directory and enter the ADB folder.
Step 3: Long press the “Shift” key, and click the right key of the mouse in the free area of the ADB folder. Then, select the option “open command window here”.
Step 4: Use a USB cable to connect the Android device that is stuck in fastboot mode with the PC.
Step 5: Enter the command “fastboot devices” in the command window and click “Enter” button on the keyboard.
Step 6: Locate your device. Then, type the command “fastboot reboot” and press “Enter”.
Way 4: Use Android Multi Tools
Android Multi Tools is a easiest third-part tool for all types of users to get out of fastboot mode quickly. After downloading the Android Multi Tool on your PC and connecting your Android phone to the computer, go to find the Android Multi Tools file and run it. Then a command prompt window will be displayed on the screen. Pressing number 9 “Exit Fastboot Mode” can help you exit fastboot mode and reset your device.
Way 5: Use iSumsoft Android Refixer
If you are using Samsung Android phones, you can also download a software called iSumsoft Android Refixer to solve the problem of stuck in fastboot mode. iSumsoft Android Refixer is aim to fix 30+ types of Android issues including stuck in fastboot mode. And it is professional and easy to operate.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
4
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
6 Комментариев
solve my phone
из Taddesse Mengist
My phone is stopped by a neck then writes mounts on the screen
{. Fastboot & rescue mode}
из juffdjoudjou
Hi, my Huawei phone is locked in Fastboot & Rescue mode. It will also not turn off. I have done the power button and volume buttons and it still does not work, I have tacken out the battery. I have went to the web site, the say to go and, it wants me to loge in but
none of the places asked for where you live is the Us, Help please
из Jessica Robinson
g630 u00 phone locked
из fuad mohammed
tenho um problema com o meu dispositivo huawei g535-l11 o dispositivo foi colocado no modo rescue
из nelson simao
Показать 1 больше комментариев
