Dropped in water now touch screen won't respond, what do I do?
Dropped my phone in water it comes on but my screen isn't responding at all. Any advice?
Это хороший вопрос?
Это хороший вопрос?
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
You will probably have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the Ifixit guide on how to dis-assemble your phone.
Alcatel One Touch Fierce Teardown
If this process seems too daunting, take your phone to a reputable, professional phone repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Был ли этот ответ полезен?
I cant get my phone to turn on for nothing what happened was i was at school with a lunch box and my water bottle wasted amd now my phone battery is red and after school i pit it in rice with the battlery out and its been in there for a month and i cant get it to work for anything i need help
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 10,921
2 Комментариев
I would suggest opening the phone up and cleaning it with minimum 98% achohol. Then try and turn it on again. Otherwise, it sounds as though the screen has gone bad.
из Imad Knight
mine its not sensoring per now
из Dhat LEGACY
