Why won't my Hp Stream 7 turn on?
I can't turn my tablet on and it's starting to frustrate me >:( any ideas on how to fix this problem?
Это хороший вопрос?
Это хороший вопрос?
Hey Brennan!
Sorry to hear about your struggle, but I think I have some ideas that could help!
- Try charging your device. It's most likely dead and a little charge could do the trick
- Try changing the screen. While opening the device, look for any connections that need to be reconnected or clean.
- Water damage is a possibility. If you have soaked your device recently, you may have some luck dissembling it, and soaking the parts in rice or salt; neither will guarantee your device will work when put back together, but success stories have brought devices back from the dead.
Best of luck!
Был ли этот ответ полезен?
Hey Brennan!
- Try Changing the screen. While opening the device, look for any connections that need to be reconnected or clean.
Best of luck!
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 545
