Tacking down the home button bracket
I am in need of help tacking the home button down so as it will not come off, suggestion please and thank you.
Это хороший вопрос?
Это хороший вопрос?
Hi
In that case you have 2 solutions.
The first and easiest : you can emulate the Home button by software. For such purpose do as follow:
1) go into settings\General\Accessibility
2) In the INTERACTION Sub menu put AssistiveTouch ON
3) Then you will see a button appearing on your screen that will emulate the Home button. You can swipe it & put it at the place of your screen you desire.
The second ; it's hardest but better : you will have to remove the digitizer using a hot gun or better a Hot air soldering/dessoldering unit and then to put back/replace the button . Possibly you will have to buy a gasket before to replace the former one (very cheap).
Good luck
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 54
